Forum >The UUID keeps changing or doesn't show up.【TEL0095】
userHead Winster 2022-10-19 01:08:14 4186 Views1 Replies
2025-03-17 15:42:27
The UUID is changing. You can try to execute FactoryReset or the BTS software restart in the lightbeacon application. A simple physical power failure restart may not be effective.
If there is no UUID, the iBeacon location service may not be enabled. You need to manually add location permissions for LightBeacon, otherwise the iBeacon monitoring function cannot be used. Please refer to the To turn on location services for App step in the wiki.
It is also possible that the battery included in the chassis may be low and you must replace the battery to find out.
userHeadPic Tonny12138
