Forum >What is 3NKCL solution for pH meter
GravityTroubleshooting
userHead Izydor.Dudek 2022-10-22 03:01:44 6234 Views1 Replies
The manual for the Gravity analog pH meter at:
 https://wiki.dfrobot.com/Gravity__Analog_pH_Sensor_Meter_Kit_V2_SKU_SEN0161-V2
says you need to immerse it in “3NKCL” solution for 8 hours before use.
What is this solution and where can I buy it?
2022-10-25 18:30:28
Hi! The cap of the probe contains protective solution (3.3mol/L KCL).
userHeadPic jenna
