Forum >Unreliable WiFi connection DFR0654 and 0.2.1 board package
userHead David.Gesswein 2022-10-25 16:52:55 1521 Views1 Replies
I had intermittent issues with WiFi getting stuck trying to connect. With this code
      WiFi.begin(ssid, password);
      while (1) {
       Serial.print(WiFi.status());
       if (WiFi.status() == WL_CONNECTED) {
         connected = 1;
         break;
       if (WiFi.status() == WL_CONNECT_FAILED) {
         break;
       delay(1000);
       Serial.print(".");
It would get stuck with  WiFi.status() returning 1 WL_NO_SSID_AVAIL so loop would never exit. It went through a other values before it continuously returned 1.  After trying various code changes with no improvement I switched to the 0.2.0 board package and the problem went away.
2023-02-24 00:07:25
HI
Sorry, there may be some error in the 0.2.1 board package, we will contact the product manager to fix this issue.
Thank you for your information.
userHeadPic NeloKin
