Forum >Recommended M.2 SSD for LattePanda Delta3
General LattePanda
userHead RicouUK 2022-11-08 03:08:44 3260 Views1 Replies
I'm looking at installing either Ubuntu or CentOS onto a Latte Panda delta 3 and running it as a headless server hidden away in a cupboard.
It looks like it has 64GB of storage already but I would like to add another 256G via M.2 SSD. Can someone recommend a card that works and fits inside the case?
Can I add 2 SSDs and (one in each slot) and run them in RAID 0 or RAID1?
Is the WDT supported by Linux? If it hangs, I would like it to automatically re-start without intervention.
TIA,
RicoUK
2023-02-22 01:51:40
For Latte Panda 3 Delta (SKU:DFR0982). You can add any Nvme SSD in M.2.M key, and SSD with SATA protocol in M.2 B key, like WD Green.
You can add two SSDs, but I'm not sure whether it can form Raid 0/1 or not. I will come back to you as soon as I get the result.
WDT function is still under development. It may be available in future.
userHeadPic NeloKin
