Forum >ME007YS waterproof ultrasonic sensor does not work. 【SEN0312】
userHead Winster 2022-11-09 17:19:36 4655 Views1 Replies
ME007YS waterproof ultrasonic sensor does not work. There is no "FF" value. The output gives the garbage value.
2025-03-17 15:41:57
When "RX" floats or input High level, the module outputs processed value, the data is more steady, response time:  100-300ms;  when input Low level, the module outputs real-time value, response time: 100ms.
userHeadPic Tonny12138
