Forum >zImage install on Raspberry PI 2
General Raspberry Pi
userHead JamesHimmerla 2022-11-12 03:40:28 1166 Views1 Replies
I have precompiled Android Kernel and modified it. After builduing I got an zImage. The Question is how can I install and boot the zImage on my raspberry pi 2?
I'm using a SD-card.
2022-12-21 03:52:20
The RPi won't load a normal zImage. You will need to use a tool called imagetool-uncompressed.py available in the Raspberry PI Tools repo to convert the zImage into the format used by the Raspberry PI.
After doing that, you can copy the https://omegle.love kernel.img file into /boot on the SD card.
There is a reasonably complete tutorial on compiling and installing https://omglz.com your own kernel here and another here. omegle.2yu.co I recommend you read these if you have not already, because there are a lot of other aspects to consider.
userHeadPic JamesHimmerla
