Forum >SEN0192 - Maximum target speed
General Gravity
userHead Erry.Berry 2022-11-20 14:16:40 1089 Views0 Replies
The product page for the SEN0192 digital microwave sensor states that the “Sensitivity” reception parameter is between 3Hz and 80Hz.
https://www.dfrobot.com/product-1403.html
Does this mean that (according to the doppler effect formula f = f₀(v + vr)/(v + vs) ) the sensor can only detect presence of targets moving between around 0.3km/h and 8.2km/h?
What happens if the target is moving faster than 8.2km/h - does it get ignored?
If I am interpreting the data correctly and the above is true, is it by any chance a matter which could be solved by modifying some band pass filter located after the IF output and the threshold detector's input to allow for higher frequencies of, say, 600Hz?
Thanks in advance.
