Forum >FireBeetle ESP32 DFR0478 - voltage divider not connected?
userHead Janko.Walski 2022-11-24 10:01:07 1308 Views5 Replies
According to the DFR0478 FireBeetle ESP32 board schematic (https://raw.githubusercontent.com/DFRobot/Wiki/master/DFR0478/%5BDFR0478%5DFireBeetle%20Board-ESP32(V4.0)%E7%94%9F%E4%BA%A7%E6%A3%80%E6%9F%A5%E5%9B%BE.PDF)  the ESP ADC1_0 pin (A0 on the board) should be connected to the voltage divider connected to the battery:
Best
2022-12-10 00:16:00
Nice article that taught me something. This post is the best one on this important subject [url=https://quordle-wordle.com/] quordle[/url]
userHeadPic Alex.reynolds
2022-12-09 13:53:08
DFRobot still didn't aswer my question. Neither here nor in the FAQ on the product page.
Fortunately another person, shadeBlue, found the solution. It seems that for unknown reasons the board has two unpopulated pads which can be bridged to make it work as expected. If someone's interested, please see the shadeBlue's answer to my thread in the product page: https://www.dfrobot.com/product-1590.html
I have no idea why the board is designed this way. The solution seems to work and unless DFRobot finally decides to tell us something, bridging those pads looks like a way to make the voltage reading work.
userHeadPic Janko.Walski
2022-11-30 15:08:14
I am facing the same issue. It seems it is not connected. Or I get a constant voltage of 0.28400 volt. Which is way to low and doesn't reflect a battery that is charging (i.e. the voltage is not increasing over hours).
So is A0 connected to the divider? Or is it simply not working?
userHeadPic Jeroen.Tuinstra
2022-11-26 02:50:05
Hello. Is this forum active? Could someone from DFRobot please answer my question?
2022-11-24 10:21:54
Somehow half of my post didn't show, here's the rest:
The A0 pin is indeed connected to the ESP32's pin 4, but when I connect a battery, the A0 pin is floating (as measured with voltmeter) and the adc1_get_raw() returns 0.
Isn't the voltage divider connected to the A0 pin? Is it connected somewhere else? How do I measure the battery voltage?
