Forum >Getting a code error of indention. Using upycraft.
userHead AnneGodkona 2022-12-01 04:25:54 331 Views1 Replies
Here is the code:
import machine import time trig = machine.Pin(2, machine.Pin.OUT) echo = machine.Pin(0, machine.Pin.IN) green = machine.Pin(12, machine.Pin.OUT)   def get_distance(): trig.value(0) time.sleep(0.0001) trig.value(1)    while echo == 1: start = time.time()  while echo == 0: end = time.time() sig_time = end-start   distance = sig_time / 0.000148   print( 'Distance: {} cm' .format(distance)) return distance while True:   get_distance()
The error is: Traceback (Most recent call last):
File stdin line 1 in module
File <string>, line 14
Indentation error: unindent does not match any outer indentation level
I am lost. It looks like my indents are correct. Please help.
2023-02-23 19:48:05
Normally, this error is caused by incorrect Indentation formats. Could you please all use TAB or all use spaces to adjust your indentation?
Hope it can help.
userHeadPic NeloKin
