Forum >How do I Calibrate Gravity: IIC Ozone Sensor?
so I've bought the Gravity: IIC Ozone Sensor for my final project related to Ozone Gas Concentration. But what I want to know is do I have to calibrate the sensor before I use it or is it automatically calibrated from itself? moreover, when I test it with the program, the result that is shown from Arduino IDE serial monitor are significantly increase by a resolution of 1 pbb, however the resolution shown from the datasheet is 10 ppb, is there anyone who could explain it?
2022-12-13 00:44:00
Winster
Hi, The sensor does not require manual calibration, but needs to be powered on for 24 hours before first use to ensure accurate readings.
View Arduino ProductsMore Arduino Related ProjectsArduino TutorialsMore Gravity ProjectsView Gravity Products
