Forum >error: 'PinStatus' does not name a type
In case you are triyng to compile any wifi / IOT example for the firebeetle ESP32
and you got the error:
this problem is caused by the wrong wifi library linked so you have to exclude wifinina
so inside Arduino go in library manager, look for wifinina e uninstall it
in platformio write in the platformio.ini file:
lib_ignore = WIFININA
ESP32 / ESP8266 ProjectsESP32 TutorialsESP8266 TutorialsESP32 / ESP8266 ProductsView Arduino ProductsMore Arduino Related ProjectsArduino Tutorials
