Forum >DFR0004 pinout
DFR0004 pinout
userHead BurtShulman 2023-01-04 06:57:07 322 Views2 Replies
I have a DFR 0004, V1.3. I need to find the timer/counter2 output pin(s). There is a green row of pins labeled DIGITAL with markings on pins 3 5 6 10 11. Above that is a row of receptacles. Above that are banks of 4 and 3 pins, labeled D. This is with the switches oriented at the bottom of the board. Also, in the M1 E1 M2 E2 jumpers, please let me know which pin is the E1 to the L298, the top pin or the bottom pin.
Thank you.
2023-02-21 01:46:07
E1 is the pin on the top. I marked it here.
userHeadPic NeloKin
2023-01-06 22:16:46
The first Romeo Arduino Control Board with Motor Drivers is based on the Arduino Uno with a socket to add bluetooth APC220 Radio Communication Module.
userHeadPic natalejulie5961
