Forum >Case with monitor/touch screen
Hello everyone. Just wondering if anyone has seen a case that will hold the Lattepanda 3 delta and a touch screen monitor in a single case. It doesn't need to open and close or anything fancy. I've seen some homebrew ones but I don't have the skills or 3d printer to make anything like it. I'm looking for anythign between 10" and 15" for the screen.
2023-05-24 02:18:25
bidrohini.bidrohini
Here you will find some 3D models of Lattepanda display case:
https://m.yeggi.com/q/lattepanda+display+case/
2023-05-23 23:54:04
xingzhao.zhu
I browsed through the web and the only larger cases I found were these ( https://kksb-cases.com/collections/lattepanda ) . Not sure if it fits your need, but you could always get a separate casing for the screen and bind the two cases together.
I hope this would help.
