Forum >RGB1602 not starting if I move script
userHead Barra 2023-01-26 05:28:55 309 Views1 Replies
Am new to Raspberrys and Linux and have just got an RGB1602 to go with it.
I have written a python script based on Button.py.  I want this script to run everytime the system reboots so have given Anyone access to execute then script.  I have changed the script line 2 from sys.path.append('../') to sys.path.append("/home/<username>/DFRobot_RGB1602_RaspberryPi/DFRobot_RGBLCD/python").
The following line has been added to /etc/rc.local:
python3 home/<username>/DFRobot_RGB1602_RaspberryPi/DFRobot_RGBLCD/python/script.py &.  This script does what it should.
However, if I move the script to /home/<username>/Documents/script.py, changing the path in /etc/rc.local and keeping the amended sys.path.append  nothing happens to the RGB1602.  How can I find out what is wrong?
