Forum >FIREBEETLE ESP32 V4 USB first Upload after compiling failed
userHead didier.Giarratano 2023-01-29 13:07:45 738 Views1 Replies
Dear All,
I would like to test the ESP32 firebeetle to check the power consumption in deep sleep mode.
I'm compiling a sketch that works on another board from another manufacturer (so not a Firebeetle V4).
I updated the "preferences" with: "https://git.oschina.net/dfrobot/FireBeetle-ESP32/raw/master/package_esp32_index.json"
In the "board manager" choice menu, I selected "FireBeele-ESP32" and the USB port.
The compilation goes well but when I try to upload the board I get the following message:
Sketch uses 1006225 bytes (76%) of program storage space. Maximum is 1310720 bytes.
Global variables use 40440 bytes (12%) of dynamic memory, leaving 287240 bytes for local variables. Maximum is 327680 bytes.
esptool.py v3.3
Serial port /dev/cu.usbserial-1450
Connecting......Traceback (most recent call last):
 File "serial/serialposix.py", line 575, in read
OSError: [Errno 6] Device not configured
During handling of the above exception, another exception occurred:
 File "esptool.py", line 468, in command
 File "esptool.py", line 413, in read
 File "esptool.py", line 3571, in slip_reader
 File "serial/serialposix.py", line 581, in read
serial.serialutil.SerialException: read failed: [Errno 6] Device not configured
 File "serial/serialposix.py", line 398, in _reconfigure_port
termios.error: (6, 'Device not configured')
 File "esptool.py", line 5387, in <module>
 File "esptool.py", line 5380, in _main
 File "esptool.py", line 4687, in main
 File "esptool.py", line 115, in get_default_connected_device
 File "esptool.py", line 664, in connect
 File "esptool.py", line 629, in _connect_attempt
 File "esptool.py", line 528, in sync
 File "esptool.py", line 484, in command
 File "serial/serialutil.py", line 372, in timeout
 File "serial/serialposix.py", line 401, in _reconfigure_port
serial.serialutil.SerialException: Could not configure port: (6, 'Device not configured')
[80926] Failed to execute script 'esptool' due to unhandled exception!
Failed uploading: uploading error: exit status 1
Do you have any idea what I should do ?
thank you in advance
