Forum >HUSKYLENS USB Connection
General HUSKYLENS
userHead FR 2023-01-30 20:34:09 702 Views2 Replies
Hi ,
Huskylens USis really a nice vision sensor.  I received mine but the problem that I have is connecting a double sided micro cable to the port.  Even though my cable has a micro USB end but it seems it is bigger than the port and does not go easily into the port. So I ordered double sided Micro USB cable (FIT 0479) for Latte Ponda from your site, hopefully it will resolve my problem.  I also have a suggestion: when you attach the mounting bracket it slightly blocks the micro USB port of the device, it would be nice if you take that into consideration in case you redesign the bracket.
2023-02-20 21:53:33
Thank you for your suggestion, we will consider improving this part in the next version of Huskylens.
userHeadPic NeloKin
