Forum >DFPlayer "SerialWrongStack" error : what does it mean ?
Hi !
I use DFPlayer on one of my projects (on a small PCB, driven by a Seeeduino Xiao). The circuit is very simple, and I already produced 10 pieces.
But on my last sample, I encounter a strange error : I get “Get wrong stack” error (when I use the test code from DFPlayer wiki page).
All contacts are OK, the PCB are produced by JLCPCB (not homemade-PCBs), same operating mode.
The test code shows the DFPlayer is online, but I got timeout error and “get wrong stack” error.
The documentation doesn't explain the purpose of this error code, do you have any idea ?
2023-02-07 07:48:04
Samy.RABIH
I found some details here : https://github.com/Makuna/DFMiniMp3/wiki/Notification-Method#static-void-onerrordfmp3-mp3-uint16_t-errorcode
So I will check wiring
