Forum >SEN0486 barcode set up
TroubleshootingGravity
userHead Max.Madaf 2023-02-08 02:10:41 1336 Views8 Replies
How would I set up the SEN0486 to scan a barcode, I can't find any resources online.
2024-03-04 05:20:08
Same here.
Both sample codes not working for me on my esp32
no recognition from the qr code scanner
userHeadPic see.hadf
Raj.Kunwor wrote:
Can you post your code, compilation error (if it happened), and output (serial or I2C) here?
2024-03-04 12:21:23
see.hadf wrote:
thanks for the quick response.
no compiling error - both example codes work in pio.
Use Pin 16 and 17 for TX/RX on a ESP32 Lora 1.3
#define FPSerial Serial1 //also with HardwareSerial
Serial1.begin(9600, SERIAL_8N1, /*rx =*/16, /*tx =*/17);
and for I2C 21 and 22.
No output on any interface.
Should be indication light work without pinning the rx/tx pin?
Because on a 3.3v power supply the led is breathing but no indication of recorgnize code.
BR
2024-03-06 04:13:44
see.hadf wrote:
@Raj.Kunwor any update on that?
2024-04-11 23:51:46
2024-03-04 05:19:26
Have the same issue with a esp32. UART and I2C not showing up and the led just breathing.
Any further assistance ?
2023-06-25 21:37:39
What board are you using? Please note that the wiring of the sensor needs to correspond to that of the selector switch.
userHeadPic jenna
2023-06-22 12:46:32
No…they are not working.  My device just changes colors and never reads any barcode of any type.
userHeadPic CharlesGiddens
2023-02-09 06:10:50
Are the sample codes not working?
https://wiki.dfrobot.com/SKU_SEN0486_Gravity_Ring_2D_QR_Code_Scanner
