Forum >Accessory Shield for Bluno - OLED not working with motor drivers
Sorry for maybe not complicated to solve problem. Below you can see a program which is dedicated for Romeo BLE - Bluetooth 4.0 board and Accessory Shield for Bluno. The problem is that when the motors procedure on board is enabled OLED screen is not working.
#include "blunoAccessory.h" #include "U8glib.h" #include <DHT.h> #define DHTPIN 2 // Pin which is connected to the DHT sensor. #define DHTTYPE DHT11 // DHT 22 (AM2302) DHT dht(DHTPIN, DHTTYPE); U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE); blunoAccessory myAccessory; //Sensor char Humm_buf[6]; char Temp_buf[6]; float temperature; float humidity; //Motor int E1 = 5; //M1 Speed Control int E2 = 6; //M2 Speed Control int M1 = 4; //M1 Direction Control int M2 = 7; //M1 Direction Control void setup() { u8g.setColorIndex(2); //displayMode : u8g_MODE_BW myAccessory.begin(); dht.begin(); } void loop() { static unsigned long DHT11Timer=millis(); //every 2s update the temperature and humidity from DHT11 sensor if (millis() - DHT11Timer >= 1000) { DHT11Timer=millis(); temperature=dht.readTemperature(); humidity=dht.readHumidity(); } u8g.firstPage(); do { //motor(); //<--- problem is here draw(); } while(u8g.nextPage()); delay(500); } void draw (void) { dtostrf(humidity,5,0,Humm_buf); dtostrf(temperature,5,0,Temp_buf); u8g.setFont(u8g_font_unifont); u8g.drawStr(0,22,"Humidity "); u8g.drawStr(70,22,Humm_buf); u8g.drawStr(113,22,"%"); u8g.drawStr(0,44,"Temperature "); u8g.drawStr(70,44,Temp_buf); u8g.drawCircle(113,37,2); u8g.drawStr(117,44,"C"); } void motor(void) { digitalWrite(M1, LOW); //LOW or HIGH analogWrite (E1, 255); //PWM Speed Control digitalWrite(M2, HIGH); //LOW or HIGH analogWrite (E2, 100); //PWM Speed Control }
2017-11-17 01:50:44 This relay is connected to digital pin 11, I don't think it could control the speed and direction, it can only make the motor rotate, and I think it should be a small motor since the voltage and current is comparatively low
robert.chen
