Forum >Husky "Error: SMBus object has no attribute 'timeout'
userHead Bill.James 2023-02-09 10:52:03 2519 Views5 Replies
We are trying to read April Tags using the following
from huskylib import HuskyLensLibrary
husky = HuskyLensLibrary("I2C","", address=0x32)
husky.algorthim("ALGORITHM_TAG_RECOGNITION")
print("Show tag now...")
while(True):
    data = husky.blocks()
    for tag in data:
        print("Tag: {}, {}, {}".format(tag.ID, tag.height, tag.width))
We are getting the error:
Traceback (most recent call last):
 File "/home/pi/Component/huskylib.py", line 178, in processReturnData
   numberOfBlocksOrArrow = int(
TypeError: int() can't convert non-string with explicit base
During handling of the above exception, another exception occurred:
 File "/home/pi/Component/husky.py", line 4, in <module>
 File "/home/pi/Component/huskylib.py", line 387, in algorthim
   return self.processReturnData()
 File "/home/pi/Component/huskylib.py", line 217, in processReturnData
   self.huskylensSer.timeout=5
AttributeError: 'SMBus' object has no attribute 'timeout'
We have tried:
pip install pysmbus
pip install pysmbus --upgrade
pip install smbus --upgrade
sudo apt install python3-smbus -y
sudo apt install python-smbus -y
2024-02-02 00:28:59
Hey Everyone, I am facing the same issue. Can anyone tell how to solve it ?
userHeadPic Nikita.Nagar
Nikita.Nagar wrote:
exampleHL.py is also not working when I am calling the algorithm.
2024-02-02 00:30:35
2023-04-18 18:41:54
Does exampleHL.py work properly? (I use Raspberry Pi 3B, python3.9, version 5.15.32. It's recommended to add sudo before the pip command.)
userHeadPic jenna
2023-04-17 07:12:26
I am experiencing the same problem as Bill.James. I am using a raspberry 4B with raspberry Pi OS 32bits.
My python version is 3.9.2.
Is there any solution to use this library in a raspberry?
Best regards,
userHeadPic Nico.BrM
2023-02-20 18:51:20
Sorry for the inconvenience.
Could you please try updating python to v3.9?
The SMBus library for Raspberry Pi is not good. We will update this library soon.
Hope it can help.
userHeadPic NeloKin
