Forum >DFPlayer Pro stopping working (DFR0768)
Troubleshooting
userHead Timóteo.Mendes 2023-02-11 05:47:41 1478 Views6 Replies
DFR0768
Hello I am trying to develop a new project and use this device.
But, after it as worked ok for some cycles sundnly it stops to work with out any reason.
If I connect it to the PC it detects, works as sound card and I can add files, when it is connect just to power it does not work and stands like a loop in the begining message.
So i tryed a new one and the same problem occurs, so it must be someting wrong with the devices.
Is it possible to reflash it?
Thanks,
Tim
2023-06-22 02:02:43
Could you pls tell me what board you use? You can upload the code.
Thanks for more details.
userHeadPic jenna
jenna wrote:
Please don't power the module through USB and GPIO at the same time.
What is the playback mode of the module?
2023-06-28 22:16:47
2023-02-21 09:11:48
Hello all,
So no reason for this to fail bu it does how can I resolve this?
Any other option besides the voltage level?
Thanks,
Tim
userHeadPic Timóteo.Mendes
2023-02-12 13:05:10
Hello bidroini,
The power should not be a problem as I am using a powerbank of 10000mAh.
Any other suggestion?
Tim
2023-02-11 06:44:16
I think the power supply is not sufficient. Kindly check the current and voltage ratings of the power supply that you're using.
