16 x 16 led matrix
All,
Ive tried to follow the instructions to setup a 16 x 16 single wire LED matrix. Ive installed the ADAfruit library and ive copied the Arduino code . When I try to compile, it says there is an error on line 16;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(256, PIN, NEO_GRB NEO_KHZ800);
With error 'Compilation error: expected primary-expression before '(' token' wont go past that unless I put // at the start.
Then it gets to line 34 and gives the error 'Compilation error: 'strip' was not declared in this scope'
The only thing I can think of is that strip is within the avr/power.h library mentioned at the start but I cant find that library anywhere?
Any help would be appreciated.
Paul
OK thanks. Found an article elsewhere that had the same program, however when I copied that version it complied and ran, dont know why but the version on here is corrupted in some way
