Forum >DC Motor withEncoder/(FIT0450)(SJ01) can use Arduino nano33?
userHead SiHwan.Hwang 2023-02-24 21:56:40 859 Views1 Replies
i have some question about encoder module
is this can read data from sensor to arduino nano33? directly?
i saw datasheet at this motor
Encoder operating voltage: 4.5~7.5V
i understand this mean "encoder's output voltage"
but nano33 operated voltage is 3.3V
i will supplyed power encoder module using 5v from nano33
(motor supplyed power other motor driver module)
nomal nano can use 5V i/o but this is 3.3V use
so can i use this directy? or use translate module 5V or 7 V to 3.3V?
2023-03-01 00:16:48
For DC Motor with Encoder/(FIT0450), it is recommended to use a development board with 5V or above operating voltage.
UNO has digital pins with 5V voltage output, 3.3V output voltage for Nano33 is not enough to work with the encoder.
Hope it can help.
userHeadPic NeloKin
