Forum >Feed an 3.3V device with Solar Power Manager 5V DFR0559
userHead David.Hergueta 2023-02-25 04:44:02 1006 Views2 Replies
I'm doing an IoT solar sensor for a project which uses an Arduino nano 33 BLE powered by a battery and the solar panel. I was looking for a device that regulates de charge of the battery through the solar panel and the Arduino power given by the battery, just like Solar Manager 5V. (Link of the product https://www.dfrobot.com/product-1712.html )
The solar panel has a 1W of power and is desinged to work at 5V. This product fits perfectly to my solar panel, however it has an output of  regulated 5V and the Arduino works with an Vdd of 3.3V. I don't know if you have a product similar to Solar Power Manager 5V but also capable of provide regulated 3.3V instead of 5V in order to feed the microcontroller, or idk if it would be better to use Solar Power Manager 5V with a Buck converter or voltage regulator to transform 5V from the power manager to 3.3V to Arduino.
I need to minimize power consumption too.
Greetings and thank you for your help.
2023-02-27 03:13:58
DFR0579 has 3.3V output, but only supports 0.5W solar panel, if the power is too small, then it can only be used in combination with buck module. By checking the official documentation of Arduino nano 33 BLE, it only supports 3.3V for IO, but the input power is supported by 5V, you can confirm again: https://docs.arduino.cc/hardware/nano-33-ble
userHeadPic Xiao
David.Hergueta wrote:
Yeah, it uses a dc/dc converter to be powered with 5V. So I think that I shouldn't have any problem.
2023-03-04 18:08:12
