Forum >Vcc for LCD 16020 Support
Suggestions
userHead rschrope 2023-03-03 05:01:38 1125 Views2 Replies
Hey guys,
I am seeing that the LCD 16020 can operate on either 3.3V or 5V from the datasheet, but I have only seen it successfully run at 5V. To run it at 3.3V, do you have to alter the software to change the contrast? I'm trying to make sure I can have it fully operational at 3.3V before I leave a boost converter off of my PCB for powering the display.
Thanks!
2023-03-04 07:52:10
All standard 16x2 LCDs need 5V to operate.
2023-03-03 18:54:34
If you are asking about I2C 16x2(1602) LCD Display Module for Arduino(SKU:DFR0063), it can only work on 5V.
userHeadPic NeloKin
