Forum >Gravity: PWM Infrared Carbon Dioxide Sensor (400-5000 ppm)
Gravity
userHead joaquim.rucar 2023-03-06 05:15:49 1287 Views3 Replies
I bought the “Infrared C02 Sensor V 2.0” and i put in arduino software the code that DF ROBOT propose here:
https://wiki.dfrobot.com/Gravity__Infrared_CO2_Sensor_For_Arduino_SKU__SEN0219
And when i try the read the measured data, i see that (in the com):
Could you help me? I do not understand why i cannot read normaly datas
2023-03-07 06:22:30
Baud rate mismatch. Kindly make the change as per NeloKin's instructions.
2023-03-06 23:26:01
Could you please change the baud rate here?
According to the WIKI of Gravity: PWM Infrared Carbon Dioxide Sensor (400-5000 ppm)(SKU:SEN0219), if you are using our demo code, you should change the baud rate to 115200.
Hope it can help.
userHeadPic NeloKin
sekiww wrote:
can I change the baudrate to 9600? because I wanted to combine my other program that support 9600 baudrate. I am using ILI 9341 TFT display program to monitor my CO2 with this sensor
2025-03-23 14:23:01
