Forum >Huskylens and Opencv
userHead mgg239 2023-03-07 13:14:50 4144 Views4 Replies
I have connected Huskylens camera to Raspberry Pi and I want to see the image seen by the camera on my computer using Opencv. I have tried several ways but I have not succeeded.
If you could help me.
Thank you.
2025-01-29 10:37:36
How can I use Huskylens with openCV to detect the orientation of an object?
userHeadPic Rishi.Ohri
2023-03-08 01:37:18
Could I somehow detect obstacles with opencv by passing it some kind of information from the camera? Without using the algorithms it has.
userHeadPic mgg239
2023-03-07 19:42:45
I'm afraid you can not do so.
Gravity: Huskylens - An Easy-to-use AI CameraSKU:SEN0305) use I2c and UART as communication protocol, which means that the baud rate is limited. You can not see the real-time image of the camera.
Hope it can help.
userHeadPic NeloKin
2023-03-08 01:37:59
