Forum >Amperimeter SEN0211 and SCT013
userHead Joan.Casals 2023-03-10 00:47:17 948 Views3 Replies
Good morning.
I am trying to measure the power of an electrical device. I use an SCT013 with a SEN0211 ( https://www.tme.com/us/es/details/df-sen0211/otros-sensores/dfrobot/sen0211/ )
I copied an example and tried it. It doesn't measure correctly. The truth is that I don't really know what I'm doing. Does anyone know or have an example that I can follow to correctly measure the power? I'm attaching the code I'm using and it doesn't measure correctly.
I have tried it with different Arduinos, please note:
For Arduino UNO, Leonardo and mega2560, etc. change VREF to 5
For Arduino Zero, Due, MKR Family, ESP32, etc. 3V3 controllers, change VREF to 3.3
Thanks.
//Potencia
const int ACPin = A3;         //set arduino signal read pin
#define ACTectionRange 20;    //set Non-invasive AC Current Sensor tection range (5A,10A,20A)
// VREF: Analog reference
// For Arduino UNO, Leonardo and mega2560, etc. change VREF to 5
// For Arduino Zero, Due, MKR Family, ESP32, etc. 3V3 controllers, change VREF to 3.3
#define VREF 3.3
 Serial.begin(9600);
 delay(1000);
 Serial.println(" ");
 Serial.println("-> Inici SETUP ");
 Serial.println("-> Ausatel Sistemes 2023 ");
 //Potencia
 Serial.println("-> Fi SETUP");
 float ACCurrentValue = readACCurrentValue(); //read AC Current Value
 Serial.print(ACCurrentValue/2);
 Serial.println(" A");
 Serial.print((ACCurrentValue/2) * 230);
 Serial.println(" W");
 delay(3000);
// Funció llegir potencia
float readACCurrentValue()
 float ACCurrtntValue = 0;
 float peakVoltage = 0;
 float voltageVirtualValue = 0;  //Vrms
 for (int i = 0; i < 6; i++)
   peakVoltage += analogRead(ACPin);   //read peak voltage
   delay(1);
 peakVoltage = peakVoltage / 6;
 voltageVirtualValue = peakVoltage * 0.707;    //change the peak voltage to the Virtual Value of voltage
 /*The circuit is amplified by 2 times, so it is divided by 2.*/
 voltageVirtualValue = (voltageVirtualValue / 1024 * VREF ) / 2;
 ACCurrtntValue = voltageVirtualValue * ACTectionRange;
 Serial.print("VoltageVirtual = "); Serial.println(voltageVirtualValue);
 //Serial.print("ACTectionRange = "); Serial.println(ACTectionRange);
 Serial.print("ACCurrtntValue = "); Serial.println(ACCurrtntValue);
 Serial.println("********************************");
 return ACCurrtntValue;
// Fi funció llegir potenies
2023-06-18 03:48:42
I think you need to follow Jenna's suggestions in this thread:
https://www.dfrobot.com/forum/topic/321012
2023-06-16 13:51:33
Hi,  I am trying to do de same but with the ESP32  and de analog reading only reads 0.    I put an variable resistor and the analog read works fine, but with the blue cable of the sensor just reads 0.
userHeadPic Luis.Correa
2023-03-22 06:43:52
https://wiki.dfrobot.com/Gravity_Analog_AC_Current_Sensor__SKU_SEN0211_
Solved, works fine.I put everything back together again, following the example and it works fine for me now. I think I had a bad contact in the feed.
userHeadPic Joan.Casals
