Forum >Motor issues with Micro: IO-BOX Expansion Board With On-board Li-ion Battery Power..
Troubleshooting
userHead wit electronics 2023-03-16 08:15:40 390 Views1 Replies
Hope this finds you testing out the Micro: IO-BOX Expansion Board With On-board Li-ion Battery Power
board and cant seem to get motor block to work in microbit.
Is this the most upto date link for makeblock codes
https://github.com/DFRobot/pxt-micro-IOBOX
simple forward reverse does not seem to work.
Thanks for help Jason
2023-03-16 22:33:04
      For micro: IO-BOX Expansion Board with On-board Li-ion Battery Power(SKU: MBT0005) Yes this is the latest and workable makecode library.
      And we just test it on the Microbit, it run perfectly well.
      Hers's my wire connection and code:
userHeadPic NeloKin
