SEN0244 Tds Library doesn't work
Hallo, i have a project with two TDS sensors on my arduino for My reverse osmosis system, your library came handy but it'seems doesn't work.
If i'm using the sample code, i can see the value, i'm using a potentiometer on A1 pin to emulate the sensor,
If i'm using the Advance code with the library, i can only see 0
the ide is 2.0.4 on arduino mega
thanks!
2023-03-17 18:14:00
ok, i found the problem, after the first calibration everything work…
but, you can't use the library for two or more TDS sensors, the library wrote the value in the same EEPROM address, so after that nothing work proprely
Kurt.Zisa
