Forum > rangefinder sensor with SKU0366 is sensitive to noise in airport environments.?
userHead galihsukmaadjie 2023-03-24 02:41:09 968 Views2 Replies
is the rangefinder sensor with SKU0366 sensitive to high noise, like in an airport environment.?
2023-05-15 01:16:14
It's not clear exactly which sensor you are talking about. If you are referring to this one:
https://wiki.dfrobot.com/Infrared_Laser_Distance_Sensor_50m_80m_SKU_SEN0366
It does not look like it has anything to do with noise.
2023-05-11 03:36:12
Sorry the DFRobot donot have the SKU0366 sensor. We found the SEN0366 but it's the Infrared Laser Distance Sensor.
So maybe you wrote the product number wrong?
SEN0366: https://www.dfrobot.com/product-2108.html
userHeadPic Yeez_B
