Forum >Can't publish anything on ThingSpeak with makecode and microbit dfrobot extension board - help
userHead daniel.schweyckart 2023-03-25 03:46:20 888 Views1 Replies
I have a dfrobot microbit environment science extension board marqued as (v3.0)
I have tried to publish data to my thingspeak channel. All is well configarated in thingspeak.
I have read the tutorial and unfortunately I'm not able to publish any data on the channel…
I've tried manualy with my firefox browser “https://api.thingspeak.com/update?api_key=xxxxxxxxxxxxxx&field1=0” and it works fine
But in the makecode program it does'nt …
My program lokks like this, what is wrong ???
Thank you for your help ;-)
2023-03-29 19:33:32
Hello
We do not have microbit environment science extension board marqued as (v3.0). Did you mean Environment Science Expansion Board V2.0 for micro:bit (SKU:MBT0034)? https://www.dfrobot.com/product-2194.html
If yes, could you please try sending a message to your Thingspeak, and check whether your board has connected to your wifi correctly or not?
Your code seems right, However, it is recommended to add a delay (for 1 second, for example) at the end of forever block, which can avoid some problem.
userHeadPic NeloKin
