Forum >SEN0524 slow refresh
Troubleshooting
userHead Manuel.Ratola 2023-03-29 08:04:51 463 Views1 Replies
I am using a sen0524 Tof laser and when I change the distance from the laser, the output distance changes linearly before giving the correct results and it takes about 6 seconds to stabilize. Is there a away to solve this and the output distance change almost imeadiatly when I move the sensor?  I used the code from the wiki: https://wiki.dfrobot.com/SKU_SEN0524_ToF_Outdoor_Laser_Ranging_Module_15m
2023-03-29 19:50:29
ToF Laser Ranging Module for Outdoor (15m) (SKU:SEN0524) is a pretty sensitive sensor and should react quickly with the change in distance.
Could you please share a video via Google drive? So we can understand what problem you are facing exactly.
userHeadPic NeloKin
