Forum >Arduino UNO with SIM7600
Troubleshooting
userHead Dirk.Vercauteren 2023-03-29 23:45:57 1246 Views5 Replies
I am using the Arduino UNO for monitoring holiday houses (AC, water leaks etc)
Until now I used G GSM shields Elcrow from DF) without any problems
With the just bought SIM7600 shield I do have problems with the communication with the board.
I do get rubbisch as answer:
          GSM is not Ready :
          AT+CSTCC⸮⸮⸮⸮T'⸮⸮b⸮⸮j
          or
          incoming
          +CMT: "+32495592615","","23/`3/29,09:41:57+08"
          Sta⸮us
I tried to change the speeds to lower than 115200 Bd but then I do not get only ????????????? answers
Can anybody help me out with this
this is the basic test code to check communication
#include <SoftwareSerial.h>
SoftwareSerial myserial(2, 3); //used  extra wiring to connect RX and TX to pin 2 and 3
 myserial.begin(115200); //Initialize virtual serial port
 Serial.begin(19200); //Initialize Arduino default serial port
 delay(1000);
icon Communication text.zip 43KB Download(0)
2023-10-07 10:14:46
I have the same problem, I receive symbols with errors:
AT+IP⸮?
+IPR: a15200
OK
Any advice ?
Pablo
userHeadPic Pablo.Lucchetti
2023-06-27 23:24:48
I was getting same ???? On using a blue Aduino board changed with a board from sparkfun a Red board didn't get?????? could it be something to do with ftdi communication
userHeadPic Stephen.Russell
jenna wrote:
Does the baud rate of the serial monitor correspond to the baud rate set in the code? Can the SIM7600 shield work with PC ManagerV1.8_160412 software?
2023-06-28 00:01:23
2023-06-27 23:20:31
2023-04-03 19:37:53
You can use "AT+IPR?" to query the current hardware baud rate to make sure your baud rate is set correctly. After determining the baud rate, use the "AT+CGPS" command to turn on the GPS, and finally enter "AT+CGPSINFO" to get the GPS data. Finally, please connect the antenna to use GPS outdoors otherwise the positioning will be inaccurate.
userHeadPic Miya.zhang
