Forum >Additionnal info on the turbidity sensor SEN0189
GravityTroubleshooting
userHead egg67 2023-03-31 05:06:12 1009 Views2 Replies
Hi there,
just trying out the turbidity sensor and had a couple of questions:
- is there a link for the schematic of the gravity board somewhere?- Is it better to operate the sensor in a dark environment or is there any build-in filter in the receiver? - can it be powered with 3,3V or is that prone to measurements errors ?
Thanks for the help
Eric
2023-03-31 19:44:50
1.The link for the schematic of the SEN0189 Gravity: Analog Turbidity Sensor for Arduino board is here:
https://github.com/Arduinolibrary/DFRobot_Turbidity_sensor/blob/master/SEN0189%20Turbidity%20sensor(V1.0)%20schematic.pdf
2.You do not have to, you can adjust the threshold potentiometer on it to do calibration.
3.No, it can only powered by 5V.
userHeadPic NeloKin
egg67 wrote:
Hi NeloKin,
Thanks for those info.
2023-04-01 00:32:18
