Forum >Beetle DFR0282 Arduino IDE upload
Troubleshooting
userHead Szabolcs.Csokas 2023-04-03 23:41:23 812 Views1 Replies
I would like to upload a smaller program to Beetle DFr0282 from arudino IDE, but I got this message:
Sketch uses 7172 bytes (25%) of program storage space. Maximum is 28672 bytes.
Global variables use 332 bytes (12%) of dynamic memory, leaving 2228 bytes for local variables. Maximum is 2560 bytes.
Connecting to programmer: .
Found programmer: Id = "CATERIN"; type = S
   Software Version = 1.0; No Hardware Version given.
Programmer supports auto addr increment.
Programmer supports buffered memory access with buffersize=128 bytes.
Programmer supports the following devices:
   Device code: 0x44
I use WIN11, IDE version 2.0.4, I use LEONARDO as board type. and I checked the port from windows, (it is port 15 - and I've choosen this in IDE too).
Thanks for the help in advance,
Szabolcs
2023-04-04 00:42:49
HI possilby it is not a problem: I switched on verbose messages on upload and can see that the code is written:
avrdude: Version 6.3-20190619        Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/        Copyright (c) 2007-2014 Joerg Wunsch
        System wide configuration file is "C:\Users\szabo\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
        Using Port                    : COM14        Using Programmer              : avr109        Overriding Baud Rate          : 57600        AVR Part                      : ATmega32U4        Chip Erase delay              : 9000 us        PAGEL                         : PD7        BS2                           : PA0        RESET disposition             : dedicated        RETRY pulse                   : SCK        serial program mode           : yes        parallel program mode         : yes        Timeout                       : 200        StabDelay                     : 100        CmdexeDelay                   : 25        SyncLoops                     : 32        ByteDelay                     : 0        PollIndex                     : 3        PollValue                     : 0x53        Memory Detail                 :
                                 Block Poll               Page                       Polled          Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack          ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- ---------          eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00          flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00          lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00          hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00          efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00          lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00          calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00          signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
        Programmer Type : butterfly        Description     : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .Found programmer: Id = "CATERIN"; type = S   Software Version = 1.0; No Hardware Version given.Programmer supports auto addr increment.Programmer supports buffered memory access with buffersize=128 bytes.
Programmer supports the following devices:   Device code: 0x44
avrdude: devcode selected: 0x44avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% -0.00s
avrdude: Device signature = 0x1e9587 (probably m32u4)avrdude: reading input file "C:\Users\szabo\AppData\Local\Temp\arduino\sketches\DCF41796CF706D52F4BCA1B81329C1D8/MotVez.ino.hex"avrdude: writing flash (7172 bytes):
Writing | ################################################## | 100% 0.55s
avrdude: 7172 bytes of flash written
avrdude done.  Thank you.
userHeadPic Szabolcs.Csokas
