Forum >Unable to get sensor readings from ambient light sensor SEN0390
Troubleshooting
userHead clifft 2023-04-05 03:04:55 1041 Views1 Replies
I've recently bought a ambient light sensor (SEN0390) and I have tested it on an Arduino and the sensor works as it should. However for my project, I'm using a Sparkfun expLoRaBLE Thing Plus and I'm unable to get any readings. The only thing that shows in the terminal is either -1 lux or 6012954.00 (lux).
This is the pins connection of the Sparkfun expLoRaBLE Thing plus.
The only thing I changed in the library was the scl and sda pins, as can be seen in the image below:
The schematic of the board with the ambient sensor is shown in the image below:
The code I'm using:
Any idea how to fix this? Thank you.
2023-06-03 02:06:52
Sorry, there are no test reports for this library with the Sparkfun expLoRaBLE Thing Plus. It is recommended that write your own code based on the ArduinoC library.
userHeadPic jenna
