Forum >Power plug description for the LP 3 Delta on board socket?
userHead bcampbell 2023-04-20 06:27:29 800 Views1 Replies
Is there a document describing the plugs on the LP 3 Delta board.  Im trying to connect it to 12vdc and also use some of the other plugs
2023-05-11 00:50:54
You could refer to the LattePanda 3 delta official Doc to get know about the socket.
https://docs.lattepanda.com/content/3rd_delta_edition/io_playability/
You could connect the DC power here to power the LattePanda.(12VDC, 3A at least)
userHeadPic Yeez_B
