Forum >Calibration
TroubleshootingGravity
Calibration
userHead Mikael Bergvall 2023-04-26 09:52:07 1025 Views4 Replies
Hi, have some problem. Have a Beetle esp32 e and have Gravity: Analog Electrical Conductivity Sensor / Meter(K=10) and Analog PH. I can calibrate the PH sensor, but next time i restart the bord its like pH:inf. The ec i not manage to calibrate, just getting >>>Failed,Try Again<<< after my calec command. Some have a solution for this. Also tried theEEPROM cleaning. No resultat. Ideas?
2023-05-06 23:08:46
The ads module can help esp32-E read analog values more stably. It is recommended to use with the ads module, please refer to:https://www.dfrobot.com/product-1730.html
userHeadPic jenna
2023-05-06 23:04:40
Does the sensors work with the ads module on the esp32-E?
userHeadPic jenna
2023-04-26 12:36:03
When I calibrate the sensors EC and PH on a UNO bord it works, But when a switch back to Beetle esp32 e the calibration dosent work and a cant calibrate on the Beetle esp32 e. So what to do? What is the best card for me to use in this case?
userHeadPic Mikael Bergvall
2023-04-26 09:53:37
