Forum > SIM7000 - Serial interface getting "Faile to set baud rate" using example code [2nd attempt]
TroubleshootingArduino
userHead PD2023 2023-04-28 03:26:40 1211 Views2 Replies
I'm using the example code from the Wiki here: https://wiki.dfrobot.com/SIM7000_Arduino_NB-IoT_LTE_GPRS_Expansion_Shield_SKU__DFR0505_DFR0572
and it's not able to set the baud rate.
The error message is “Faile to set baud rate” (sic)
I've followed the HW & SW requirements exact and used the example code without modification.
Do I have a faulty device, or am I missing something?
Attached screenshot of Adruino IDE with code and Serial Monitor panels
Thanks!
2023-05-05 06:22:27
I think the baud rate is not set to 19200. To set the baud rate to a desired value, you have to use the AT command
AT+IPR=<rate>
https://cdn.geekfactory.mx/sim7000g/SIM7000%20Series_AT%20Command%20Manual_V1.06.pdf
2023-05-04 22:53:33
https://www.dfrobot.com/forum/topic/315636
userHeadPic jenna
