Forum >FireBeetle ESP32 and DFPlayer Mini
Have a FireBeetle ESP32 (DFR0478) that I need to connect a DFPlayer Mini to. So far I have had no luck. Have opened the example DFPlayer files, have changed to the HardwareSerial and made sure my pins were D2 & D3. Still nothing. Constantly tells me to check the connection or put an SD card in.
Tried the same examples with a UNO 3 and it works fine.
What am I doing wrong or can the FireBeetle not talk to the DFPlayer???
--Paul
2023-05-19 18:28:53
jenna
We will update the sample code at the end of this month. Thanks for your patience.
