Forum >SIM7000E NOT WORK
Troubleshooting
SIM7000E NOT WORK
userHead marcelo2 2023-05-03 07:12:35 695 Views1 Replies
Hello, I bought a sim7000e shield and I already tried many codes and even the base code is not working. What I need to do is connect it to the internet. Does anyone know how to resolve?
Olá, eu comprei um shield sim7000e e eu já tentei muitos códigos e mesmo o código base não está funcionando. O que eu preciso fazer é liga-lo á internet. Alguém sabe como resolver?
2023-05-04 00:27:28
Hello, what power supply are you using? If you power up these modules with the Arduino board, they do not work. You have to use a separate compatible power adapter. If you want to connect the module with an Arduino, you have to connect thw grounds too. Here is a project you can see for some idea:
https://www.pcbway.com/project/shareproject/4G_LTE_TempSensor_v1_2_SIM7000_74f64b71.html
