Forum >SD mmc pins of Firebeetle 2 Esp32-E
userHead Ben.Ben 2023-05-06 02:57:53 976 Views1 Replies
Hi there,
Does anyone know what pins I can use for interfacing with SD in mmc mode?
Are they different from the ones on this page?
https://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-reference/peripherals/sdmmc_host.html
2023-05-10 18:52:18
Greetings!
If my understanding was correct, the SD card can use the SPI communication,
wiki link: https://wiki.dfrobot.com/FireBeetle_Board_ESP32_E_SKU_DFR0654#target_18
The corresponding GPIO pins are therefore:
there is also an example of using an SD card module:https://wiki.dfrobot.com/SD_Module__SKU__DFR0071_
Be aware that some module requires 5V rather than 3.3V, you probably wanna check their specifications.
Regards,
userHeadPic xingzhao.zhu
