Forum >Sigma fan bad after one day?
userHead Wtg 2023-05-07 12:48:00 983 Views4 Replies
Got a Sigma kit with SSD and wifi. Fan worked for 1 day.
Left sigma off over night.
Added more ssds.
Reboot and fan will not start.
Check BIOS. Set to full try lowering temp. Still no fan.
Is it a bad fan?
2023-05-10 23:43:42
Sorry for the inconvenience,  pls contact technical support email for help: techsupport@dfrobot.com
userHeadPic jenna
2023-05-08 19:18:35
pls check the wiki: https://docs.lattepanda.com/content/sigma_edition/BIOS_Setup/#cpu-cooling-fan-settings
Path: BIOS Setup -> Advanced -> Hardware Monitor -> CPU Fan Mode->full speed
userHeadPic jenna
Wtg wrote:
did check that. Then I removed the fan. Found that the blue wire was damaged as it was in the way of the fan. Very disappointed in the quality. have pictures.
2023-05-09 19:27:10
Wtg wrote:
2023-05-09 19:28:12
