Forum >Relay contact specs for SKU:SEN0454 Water Leak Detector
userHead Kevin.Sekeres 2023-05-11 09:53:28 344 Views3 Replies
What voltage(s) and current are the sensor's form C contacts rated for?
Thanks!
2023-05-13 08:43:05
The form c contacts are housed (hermetically sealed?) inside the sensor so there's no way to provide a picture.
userHeadPic Kevin.Sekeres
2023-05-13 08:41:31
These are the sensor's voltage supply requirements and current draw. What I need to know are the voltage and current ratings for it's internal form C relay contacts i.e. N.O. and N.C. that switch states when liquid is detected, this is not provided in the spec. thanks!
2023-05-11 17:10:04
The operating Current and Voltage is 30mA and 7-18V, if that's what you are asking.
Could you show the C contacts you mentioned with a picture?
userHeadPic Yeez_B
