Forum >Why my H2 sensor showing more than 1000 ppm value ?
TroubleshootingGravity
userHead Parth.Kulkarni 2023-05-16 03:38:32 566 Views1 Replies
i am using H2 sensor in I2C mode in initiative mode on some occasion it is showing more than 1000 ppm value from data sheet its maximum limit is only 1000 ppm then why it showing more than 1000 ppm value some time that value is closer to even 2000 ppm
2023-05-16 18:05:20
Does the H2 concentration in the test environment exceed 1000ppm? This sensor can output a value that exceeds the range, but it is not recommended to refer to this value. The output in the measuring range is more accurate.
userHeadPic jenna
