Forum >Firebeetle 2 ESP32-E I2C connection cannot working if I also use UART
userHead Muhammad Ahsan Fillah.Abadi 2023-05-27 02:38:52 1891 Views2 Replies
Hello. I'm using Firebeetle 2 ESP32-E. Why I2C connection for HuskyLens cannot working if I also use UART connection for DFPlayer Pro DF1201S? Any suggestion?
Here is my code:
#include <SoftwareSerial.h>
#include "HUSKYLENS.h"
#include <DFRobot_DF1201S.h>
HUSKYLENS huskylens;
SoftwareSerial PSerial(25, 26);
DFRobot_DF1201S DF1201S;
float PERSON, LABCOAT;
void printResult(HUSKYLENSResult result);
//HUSKYLENS green line >> Pin 10; blue line >> Pin 11
  Serial.begin(115200);
  Wire.begin();
  while (!huskylens.begin(Wire))
    Serial.println(F("Begin failed!"));
    Serial.println(F("1.Please recheck the \"Protocol Type\" in HUSKYLENS (General Settings>>Protocol Type>>I2C)"));
    Serial.println(F("2.Please recheck the connection."));
    delay(100);
    PSerial.begin(9600);
    DF1201S.setVol(100);
    while(!DF1201S.begin(PSerial))
      Serial.println("Init failed, please check the wire connection!");
      delay(100);
  PERSON = 0;
  huskylens.writeAlgorithm(ALGORITHM_OBJECT_RECOGNITION);
  huskylens.requestBlocksLearned();
  while (huskylens.available()) {
    HUSKYLENSResult result = huskylens.read();
    if (result.command == COMMAND_RETURN_BLOCK){
      if (result.ID == 1){
        PERSON = 1;
  while ((PERSON == 1)) {
    huskylens.writeAlgorithm(ALGORITHM_OBJECT_CLASSIFICATION);
    LABCOAT = 0;
    while (!(LABCOAT == 1)) {
      if(result.ID == 1){
        huskylens.clearCustomText();
        huskylens.customText("Using Lab Coat", 230, 35);
        DF1201S.playFileNum(1);
        LABCOAT = 1;
      else {
        huskylens.customText("Not Using Lab Coat", 230, 35);
        DF1201S.playFileNum(2);
        LABCOAT = 0;
  Serial.print(LABCOAT);
2023-05-29 23:21:04
Download the complete code:https://drive.google.com/file/d/1J7GdBRk3V-jkLjal5alMt99SpFTx5bqe/view?usp=sharing
userHeadPic jenna
2023-05-29 23:16:22
pls try this code. This code has been verified successfully.
Here is my code:(HUSKYLENS →IIC,DFRobot_DF1201S→HardWare UART)
#include <SoftwareSerial.h>#include "HUSKYLENS.h"#include <DFRobot_DF1201S.h>
HUSKYLENS huskylens;//SoftwareSerial PSerial(25, 26);DFRobot_DF1201S DF1201S;
//HUSKYLENS green line >> Pin 10; blue line >> Pin 11//DF1201S TX,RX——> ESP32-E TX,RXvoid setup() { Serial.begin(115200);     while(!DF1201S.begin(Serial))   {     Serial.println("Init failed, please check the wire connection!");     delay(1000);   }   DF1201S.setVol(20);      Serial.print("VOL:"); /*Get volume*/ Serial.println(DF1201S.getVol()); /*Enter music mode*/ DF1201S.switchFunction(DF1201S.MUSIC); /*Wait for the end of the prompt tone */ delay(2000); /*Set playback mode to "repeat all"*/ DF1201S.setPlayMode(DF1201S.ALLCYCLE); Serial.print("PlayMode:"); /*Get playback mode*/ Serial.println(DF1201S.getPlayMode());  Wire.begin(); while (!huskylens.begin(Wire)) {   Serial.println(F("Begin failed!"));   Serial.println(F("1.Please recheck the \"Protocol Type\" in HUSKYLENS (General Settings>>Protocol Type>>I2C)"));   Serial.println(F("2.Please recheck the connection."));   delay(100); }   //PSerial.begin(9600);
}void loop(){    if (!huskylens.request()) Serial.println(F("Fail to request data from HUSKYLENS, recheck the connection!"));   else if(!huskylens.isLearned()) Serial.println(F("Nothing learned, press learn button on HUSKYLENS to learn one!"));   else if(!huskylens.available()) Serial.println(F("No block or arrow appears on the screen!"));   else   {       Serial.println(F("###########"));       while (huskylens.available())       {           HUSKYLENSResult result = huskylens.read();           printResult(result);       }       }     Serial.println("Start playing"); /*Start playing*/ DF1201S.start(); delay(3000); }
 void printResult(HUSKYLENSResult result){   if (result.command == COMMAND_RETURN_BLOCK){       Serial.println(String()+F("Block:xCenter=")+result.xCenter+F(",yCenter=")+result.yCenter+F(",width=")+result.width+F(",height=")+result.height+F(",ID=")+result.ID);   }   else if (result.command == COMMAND_RETURN_ARROW){       Serial.println(String()+F("Arrow:xOrigin=")+result.xOrigin+F(",yOrigin=")+result.yOrigin+F(",xTarget=")+result.xTarget+F(",yTarget=")+result.yTarget+F(",ID=")+result.ID);   }   else{       Serial.println("Object unknown!");   }}
userHeadPic jenna
