Forum >KIT0139
KIT0139
userHead Alex.Centelles 2023-06-03 03:22:56 477 Views2 Replies
Could I use KIT0139 for fuel and water ?
2023-06-03 09:57:23
Yes. Water,oil both are supported. The description days “ even mash with large viscosity”, so fuel should not make a problem here.
Joe.Vigil wrote:
I have an application to use this sensor in a diesel tank for level measurement.  What spec does it meet when using this sensor in a combustible environment?  Explosion Proof Class 1 Div. 1, MIL-STD-810, both,  and/or other.  Need to know that the construction and use is acceptable by a recognized and accepted standard.  Thanks!
2024-11-08 06:53:13
