Forum >Maqueen Plus V2 Extension within Make Code for micro:bit: which one?
The Wiki Page regarding Maqueen Plus reports the link where to find Maqueen Plus V2 extension to be used within Make Code for microbit. When added, the extension is shown in the menu as “+ maqueenPlusV2”.
In the same Wiki page a Maqueen Plus V2 project for Make Code for microbit is reported further ahead; in this project a specific extension is added and its name is “Maqueen Plus V2”. Some blocks in this extension are different from the other extension.
Both extensions seems to work the same way.
Are they the same so I can use one or the other equally?
2023-06-05 18:04:25
jenna
Both of these are Maqueen Plus V2 Extension, but different versions. You can load the latest version of the library by filling in the link.
