Forum >Speech Synthesis Gravity Module 2.0
userHead Hugues.Lecoeuche 2023-06-04 14:57:51 2223 Views6 Replies
I am using my brand new Gravity Speech 2.0 DFR0760 module.
I have read in the documentation of the XFS5152 that it has the ability to generate sounds (like telephone rings or sounds from 1980 arcade games) using the command “[x1]sound101 sound102 sound103 sound104 sound105 sound106
However, I cannot make the module generate sounds. It will pronounce the text outside of the square brackets and pronouce: “sound 1 0 4”,…..
Can you confirm if the module should be able to generate sounds?
Regards
H
2023-06-13 10:43:58
Thanks Jenna.
I think this settles it:
The “[x1]” command is not supported by the Gravity Module version 2.0
Thanks for your help.
Regards.
userHeadPic Hugues.Lecoeuche
2023-06-11 09:18:47
Are you able to confirm if the Gravity Speech 2.0 module supports the "[x1]" command to generate sounds?
It is a simple question and a simple Yes or No answer would suffice.
Regards
H
jenna wrote:
Hi!
I checked the DFRobot_SpeechSynthesis_V2.cpp of this product and found no code or description about [x?]. I'm afraid this product can't call the function about [x?].
2023-06-13 00:09:53
jenna wrote:
Please refer to the commands given in our tutorial. We've tested it and it works.
e.g.
ss.speak(F("[h1]Hello [h2]world"));
Control Identifiers
2023-06-13 00:40:51
2023-06-07 02:38:54
Hi.
I am using the library for the V2 module (i.e. the library that you indicated).
However the documentation from DFRobot only mentions these commands:
There is NO mention of a command “[x0]” or “[x1]”.
The standard documentation for the XFS5152CE (https://cdn.hackaday.io/files/1907328160277888/XFS5152CE_en.pdf) states on page 43 that the module should accept “[x1]” to generate sounds:
So my question to you is: Is the command “[x?]” supported by the Gravity Speech Module V2.0
Your library does not contain any command with this string/instruction either.
Regards
H
2023-06-05 00:44:10
Hello, I request you to check the module with the code given in this wiki page:
https://wiki.dfrobot.com/Gravity_Speech_Synthesis_Module_V2_SKU_DFR0760
If it works, then you can be sure that there is no problem with your module. You will need to check your code.
